Oil Psi seems to be stumping me.
Old May 8, 2012 | 07:56 AM
bvillarreal's Avatar
Icon2 Oil Psi seems to be stumping me.
I have an ls/vtec with a b16 head, changed oil pump yesterday to a 96 gsr pump, and still max i see on my gauge is 50 psi. Using 10w30 valvoline non synthetic oil. I do have an external oil cooler and an endyn breather setup but i dont think that could lower psi that much right?!
Old May 8, 2012 | 08:08 AM
doood's Avatar
been there done that
Default Re: Oil Psi seems to be stumping me.
where are you taking the reading from?
Old May 8, 2012 | 08:09 AM
back of the block from stock sending unit its teed into there
Old May 8, 2012 | 08:50 AM
oil lines go like so.....
sandwich plate feeds vtec and oil cooler, sending unit feeds turbo and oil pressure gauge
Old May 8, 2012 | 09:50 AM
ttt
Old May 8, 2012 | 12:14 PM
h2.4's Avatar
what rpm's and oil temp matter a little here. what oil pressure when fully warmed up at idle and at 3000rpm. minimum 10psi at idle and 50psi at 3000rpm when fully warmed up. using standard weight oil.
Old May 8, 2012 | 12:49 PM
At warmed up idle about 15 psi and 3000 45-50 ps. Just seems like my.gauge is off but idk!
Old May 8, 2012 | 01:33 PM
Ttt
Old May 8, 2012 | 07:32 PM
bump
Old May 8, 2012 | 08:49 PM
dueyx99's Avatar
what size oil line to cooler? what type of oil pressure gauge?
Old May 9, 2012 | 04:14 AM
autometer cobalt gauge and heres a picture of the line, dont know exactly what size but its not small. yet not overly huge
Old May 9, 2012 | 07:29 AM
No oil leaks, good compression, good oil level. Confused
Old May 9, 2012 | 11:09 AM
h2.4's Avatar
how much air flow does your cooler get there? maybe move it to the front grill area. Did you read my first post about oil pressure readings?
Old May 9, 2012 | 11:42 AM
Nobody huh?
Old May 9, 2012 | 11:55 AM
It gets optimal flow i have a vent cut out with air dorectly to it and also 2 computer fans mounted under it
Old May 9, 2012 | 12:16 PM
dueyx99's Avatar
still haven't answered my question as to what type of gauge your running, just said the model, is it electric or mechanical? and instead of posting a pic of the cooler, which is completely useless, find out what size of line you have running to it, also any type of elbows at all feeding the gauge?
Old May 9, 2012 | 01:37 PM
mechanical gauge, no elbows feeding the gauge, straight off of a tee in the sending unit, i will find out what size the line is
Old May 9, 2012 | 06:07 PM
they are 3/8 lines
Old May 10, 2012 | 08:51 AM
Ttt
Old May 10, 2012 | 08:00 PM
just read a post and someone said that taking the breather box out will cause loss in pressure and no pcv valve? But pcv valves arent good for boost? help!
Old May 10, 2012 | 11:42 PM
rich7777's Avatar
I lol'd hard when i seen that oil cooler. I'm sure placing it on your passenger seat would work just as well.
Old May 11, 2012 | 04:01 AM
i didnt put it in, kid before me did, why? I have no clue
Old May 11, 2012 | 07:00 AM
But thank you rich7777 for your negative input :D
Old May 11, 2012 | 10:32 AM
rich7777's Avatar
It's Ok, give me some time and I'll take a proper look at your thread. I'm quite clued up with oil pressure related problems. Pm me tomorrow afternoon if i forget.
Old May 11, 2012 | 04:16 PM
So my tuner just came and enabled vtec just in case my gauge was getting a fudged up reading and it is actually losing pressure over 5k rpms. Would this be from feeding everything? I'm thinking of just taking the oil cooler off. Anyone know the size of the plugs for sandwich plate off the top of your heads?
