problem with clutch (h22 act)
Long story shortt bought a 94 accord with a built h22 non running....tore it apart rebuilt iit and put it back in and went to start it and it lunged forward....so replaced the slave and master and still lunges.....so decided to try some things and when i put in a 3/4 inch spacerbetween the slave and clutch fork clutch works fine....seems like the slave should work that far but doesnt only goes in and out about an inch....anyone have any ideas
I bleed it close to 10 minutes....it does seem like theres air but the bubbles stoped after the first 5 minutes....seems odd becuase the pedal is sooo soft untill i added spacers and it seemed normal....isthere a shorter or longer slave cylinder from accords to preludes....im almost to the point of just making a bracket to move the slave over 3/4 of an inch
