need help with intake install on my accord
It's a vacuum operated resonator. It is used to reduce the noise given off by the intake the stock intake at certain RPM/load ranges. You can remove it. Make sure to plug the vacuum hoses or remove them and cap the hose barb.
Vacuum ports, vacuum hose barbs or hose connectors
You can remove the solenoid and the vacuum hose. Then cap the vacuum port so you don't get a vacuum leak.
thanks man thats what i needed to know also to the dglsmyer dude calm down i needed five post to activate my account im still learning this site so just chill the world dose not revolve around you
You're welcome
Good luck with your intake install. There is a lot of information to be found on this site. Stick around and you can learn quite a bit about your car.
thanks man i was workin on my accord today tryin to change my rotor in the front out and i couldn't get the hub off i could'nt get the lower ball joint out how can i get that out any idea
Us a slide hammer for the hub and a pickle fork for the ball joint. There are other methods for breaking the ball joint. If you take a look on youtube there is one using a long wrench and a jack.
@ 0:41 of this video is shows you the wrench trick.
http://www.youtube.com/watch?v=tiwuC...ture=endscreen
PM sent
PM sent
