95 honda accord ex v-tech
Old May 7, 2012 | 04:10 PM
95accord327's Avatar
Default 95 honda accord ex v-tech
hey everyone im new at this so please bare with me i have a 95 honda accord ex v-tech f22b1 i think not sure i know its an f22 though i need help putting on a intake i took the oem off and there is this little black box above the motor had mount i had to take it off the intake it also has a wire that hooks up to something what is that and can i remove it thank you
Old May 7, 2012 | 05:11 PM
jroxz44's Avatar
Default Re: 95 honda accord ex v-tech
That black box is a vaccume thing that silences the air charge i beleive. I removed the box but left the silinoid hooked up i just tucked it down somewhere so i didnt get a check engine light. Also i followed thay vaccume hose back to the throttle body and blocked it off with a plug removed the airbox also it gets in the way. And on my car i had to ziptie my battery forward alittle it was right in the way for one if my bends. Go look at my pics you can see. I can tell u what pipe you need if u dont already have it
Old May 8, 2012 | 01:36 AM
GhostAccord's Avatar
You can completely remove the resonator (vacuum thing) and it's solenoid without throwing a code (check engine light). The air intake resonator is not part of the PGM-FI control system. Make sure to plug any vacuum ports (hose barbs/connectors) that you disconnect and you will be good to go.
Vacuum ports (hose barbs)
Baileyduncan
Dec 1, 2015 03:18 PM
DinoReal
Feb 8, 2014 11:30 AM
1fastvtec
Mar 6, 2006 07:24 AM
supervetteracer
Jun 4, 2005 09:19 PM
iLUVmyACCORD
Jan 15, 2005 11:45 AM
