gsr tranny no more 5th gear!
hey all, ive got a b16a2 with gsr tranny in my ek hatch, she wont go into 5th gear anymore and if iam lucky enough to get it in 5th gear it pops out once i let off the gas, im guessing the tranny is on its way out? it shifts perfect everyother gear, i checked the fluid and it was very low( previous owner) i added a quart of 10w30 and shifting of other gears improved however the 5th gear remained the same. when i try to put it in gear it grinds and whins bad. im guessing its time to move on am i correct with this what is your guys oppinons. im guessing it was ran low on fluid for to long of a period and the syncros rtc are shot
Looks like you burned up the 5th gear. Common on transmissions that have been run low on fluid. I would get it open and see whether or not it is worth fixing. Check the rest of the gears for oil deprivation. The bearings also take a lot and would also suggest taking a close look at them as well.
Rod.
Nov 7, 2004 01:13 AM
Forrest Gump 9
Aug 21, 2003 09:55 AM
