Precision turbo. Tial wastegate. FIC injectors.
Im selling my Precision 6266 t3 turbo. 2.5" vband discharge. Has less than 25 miles and made 9psi one time. In brand new condition. 800 firm
Also selling a tial 2 bolt 38mm wastegate and dump tube. 9psi spring. 160
I have a oil feed and return line kit that I used on my setup, includes a -3 steel braided feed line. With the fitting for the back of the block and for the turbo. Also have a -10 braided return line wrapped in heat tape. Comes with a straight, 45 degree and 90 degree swivel an fitting with it. The fitting for drain port on the turbo is included. Also including the steel k24 oil pan that has the an bung welded into it. 100 firm for all that.
Lastly fuel injector clinic 1000cc K series injectors with clips. These also only have 25 miles on them and a bit of idle time.
slowcivic e g
May 7, 2012 05:23 AM
