REAR MAIN SEAL QUESTION. B16 99 EM1
Old May 6, 2012 | 03:20 PM
Si818's Avatar
Default REAR MAIN SEAL QUESTION. B16 99 EM1
I have a bad oil leak, which I believe is going to be the rear main seal.
However, my vtec solenoid is leaking and I have two spots it leaks. In the middle and under the tranny. What should I change when changing the rear main seal? I keep getting told there is another gasket next to the crankshaft seal.
THE CAR IS A 99 CIVIC SI (EM1) 5 SPEED.
B16A siR 2nd gen
Old May 6, 2012 | 04:18 PM
Guateracer1's Avatar
Default Re: REAR MAIN SEAL QUESTION. B16 99 EM1
The front main seal??
Old May 6, 2012 | 04:22 PM
Si818's Avatar
no, not that one.
I'm thinking whoever told me to change another seal is full of it lol.
Old May 6, 2012 | 05:48 PM
crawfo661's Avatar
Start with changing your vtec solenoid screen/gasket. If you know you have a problem there its always best to start with the easy stuff. I have seen vtec solenoid gaskets leak all over the damn place. You may be surprised and have that be your only problem. Also you should have 1 rear and 1 front main seal. Thats it.
Old May 6, 2012 | 06:29 PM
Hidenplanvew's Avatar
if you do a rear main you might as well change your clutch
Old May 6, 2012 | 06:58 PM
98civdx's Avatar
Master Detailer
YES!
Change the easy seals first, if the leak continues replace the main.
alvinahmed
May 24, 2013 01:23 PM
deeboi
Jan 21, 2013 10:25 PM
Si818
May 7, 2012 07:17 AM
zrs6v4
Oct 14, 2009 09:52 AM
EF mark
Mar 26, 2006 12:40 PM
