Gas / Temp Display
Hello Everyone,
I just Purchase a 95 Prelude...
The previous owner has told me the Gas / Temp Display does not work and that hes tried to fix it with No Luck....He says he has Changed out the Pod/Cluster and still not working...I believe he has changed it because he gave be the one he pulled out...
Can anyone please give me some information or a "map" to start troubleshooting the problem?
Thank you,
Phil
Thank you,
Phil
Common problem with these cars, you can either find a new one or a quick google search on gauge cluster or instrument panel repair shows tons of results, may even be places local to you.
First though at least check if power is getting to the cluster, if so I wouldn't bother testing anything else, replace or repair the cluster.
MTarry
11
Jan 15, 2013 06:46 PM
trooper0641
Sep 1, 2004 11:13 AM
jdmhondageek
Mar 19, 2002 07:57 PM
