EF7 brakes, tie rods, ball joint, vacuum lines. What do I tell the parts desk?
Stupid questions probably but Id like to be sure. Im orderring a heap of parts online through rock auto and ebay mostly. And theres a few parts I want to replace that I dont know which car/trim etc to buy.
The car is an 89 jdm honda crx si. Dohc zc motor.
Are the brakes the same as a crx si here? It has 4 wheel disk brakes and I dont think 89's have that here so Im not sure what to buy. I want new rotors and pads for all 4 corners.
The cars outer tie rods have alot of play and easy movement and the one's boot is almost completely missing it is so destroyed. Might aswell do the inner tie rods if Im going to do the outer. Are they the same as USDM crx tie rods?
I also need new stabilizer end bushings but Im probably going to find poly ones. Same as USDM?
Im also curious what size ID the small vacuum line is on our intake manifolds/firewall. The size that goes to the FPR and a few ports on the intake and MAP sensor. I measured and got about 4mm but wasnt sure what the spec size is.
Thanks guys
Thanks guys
Vagitarian
14
May 9, 2012 10:24 PM
JesseCRX
Dec 24, 2007 04:29 PM
jackmode9316
Jul 16, 2007 01:23 PM
Mr_CRX
13
Feb 2, 2006 08:23 PM
