sohc zc and dohc zc wiring exactly the same?
So I'm dropping a sohc ZC into my dx crx.
I've read through quite a few DX-ZC write-ups and I've noticed that all of them failed to mention if they are assuming you have a SOHC or a DOHC ZC.
This example is the one I was planning to use. http://www.zcspeed.com/DXZCwiring.pdf
Does this mean it's safe to assume that wiring between the sohc and dohc ZCs are exactly the same? I wanted to be sure before I start hacking up my harness.
SOHC ZC and DOHC ZC wiring is not the same - SOHC ZC wiring is almost the same as D16A6 wiring - the main difference is at the distributor
use the attached pdf:
