Go-autoworks new turbo parts D16z6 S300 PLX wideband
Old May 5, 2012 | 11:41 PM
dukkillertl1000's Avatar
Default Go-autoworks new turbo parts D16z6 S300 PLX wideband
PICS. http://s1249.photobucket.com/albums/...cpZZ1QQtppZZ20
Parting out the car so if you don't see it just ask
New Dizzy used for 3 races $120
New Magnacore sparkplug wires $50
new HA Motorsports S300 P28 ECU $450
PLX wideband sensor and DM5 gauge $160
Mishimoto radiator hose kit $70
Feed and return oil lines with an fittings $80
RC550 injectors used for 30min with new o-rings and seals $170
All new Go Autoworks turbo parts
ceramic coated T3 D-series cast manifold $150
Precision 39mm wastgate $190
2 core full size radiator and fan kit $180
back door intercooler with heat disbursement $150
Moroso turbo oil pan$120
2 88-91 SI cable transmissions $150 each
Running D16Z6 $400
1991 Civic Base shell with title $650
Front and rear lower control arms with energy bushing kit installed used 3 races $150
Energy poly motor mount kit all mounts $60
Russell steel brakes lines used 3 races $60
88-91 Civic EX knuckles and prop. valve $120
88-91 rear brake drums, shoes and hubs used 3 races $100
I am parting out the car so everything is for sale......
303-720-1393
dukkillertl1000
May 29, 2012 07:09 PM
dukkillertl1000
May 6, 2012 11:17 AM
dukkillertl1000
May 3, 2012 02:48 AM
dukkillertl1000
May 1, 2012 11:49 AM
