bad ect affecting idle?
Old May 5, 2012 | 06:03 PM
t_seymour's Avatar
Default bad ect affecting idle?
Can anyone tell me if a bad ECT can affect the idle speed? This is on an 89 Accord with the A20A3. Thanks.
Old May 5, 2012 | 06:27 PM
patroick67's Avatar
Default Re: bad ect affecting idle?
it did on my h22 I fixed it cleared out the code on my s300 and it idled fine so its possible.
Old May 5, 2012 | 06:42 PM
t_seymour's Avatar
Ok thanks. The CEL came on and it started idling at 1500 RPMs and the only code it threw was bad ECT, so hopefully a new one will sort it out.
Old May 6, 2012 | 10:49 AM
fcm's Avatar
fcm
Old Fart
You do know there are three (3) "ECT"
ECT switch - controls rad fan.
ECT sensor - supplies ECU/ECM with engine temp.
ECT sending unit - for the temp gauge in cluster.
The ECT sensor if bad would allow engine to run rich. 94
Old May 6, 2012 | 10:55 AM
EF9_TryMe's Avatar
Couldn't of said it better myself.
Old May 6, 2012 | 09:14 PM
t_seymour's Avatar
Well I replaced the ECT sensor and cleared the code, all went well, it idles right at 1000RPMs now as opposed to 1500, but now it bucks for a bit under light acceleration for about 20 seconds and the proceeds to run fine until I stop at a stoplight. While leaving the stoplight it bucks again almost like it is misfiring but it has not triggered the CEL. Any suggestions?
Old May 7, 2012 | 04:09 AM
EF9_TryMe's Avatar
If you think it has a misfire it's got to be one of the following
1. Spark
2. Injection
3. Compression
Those three variables have their own specific tests in order to find out what is wrong with the car when there is a 'misfire.'
Did you use a brand new ECT or a used one ?
Old May 7, 2012 | 02:03 PM
t_seymour's Avatar
Brand new ECT, however I suspect that the timing belt has jumped because at higher RPMs it runs fine, it just "misses" from idle to around 3500 RPMs, after that it runs like a champ
Old May 7, 2012 | 09:44 PM
t_seymour's Avatar
Joke was on me, cylinder 4 fouled a plug, all is good now
Old May 8, 2012 | 08:28 AM
t_seymour's Avatar
Fixed the plug, didnt fix the problem, I think I'll give up
Old May 8, 2012 | 11:42 AM
wmac's Avatar
what was the compression in that cylinder?
Old May 9, 2012 | 06:19 AM
t_seymour's Avatar
I havent checked the compression yet due to weather, however what are the chances its a TPS going bad?
Old May 12, 2012 | 04:12 PM
EF9_TryMe's Avatar
Usually your car will prevent itself from accelerating and picking up any type of load(stalling) if a bad TPS is present, and most likely it will throw a code.
But then again I've seen many escape the illuminated CEL light(dtc code) where it will be a bad TPS sensor, but no signs of a CEL.
Only way to test a potentiometer like that is to put a multimeter to it, and measure voltage at closed throttle and WOT throttle. Now when your doing this, you also have to note down the increase in voltage by steps, there can't be any disturbance in such a test or voltage variation. The numbers have to progress gradually as you progress at the same rate with the throttle blade.
dragon_lowrider
Sep 22, 2010 10:55 PM
reed857
29
Jul 26, 2009 10:57 AM
higgunscrx
Apr 15, 2008 12:28 PM
black sohc civic
Oct 30, 2005 07:02 PM
