92 Accord with a CEL code 43
So according to some of the more knowledgable folks, and thanks for sharing, this is a fuel system supply code. I have not reset the ECU to make sure it comes back but besides that, any advice on where to start on anyhting obvious would help.
Used FiveTen's advice and didn't get any voltage out. Also went with one books recommended bench test for resistance readings between pins A/B and also A/C and A/D. All showed completely open. Brough the sensor to the auto shop and measured the new sensor's resistance measurements and they also showed completely open when there should have been something between 10 and 40 ohms between A/B. Anyway, replaced the sensor and haven't had the CEL come up again after a couple of days driving. So I am calling it fixed.
