mini me dont understand this
Old May 5, 2012 | 12:15 AM
EF2SLOW's Avatar
Default mini me dont understand this
So I did a mini me and it started but would die if I didn't stay on tue gas now it doesn't start I have fuel air and no spark I've timed and timed it nothing works this car is prob after prob after prob if I can't fix this im junking this piece of ****
Old May 5, 2012 | 03:49 AM
grumblemarc's Avatar
The Grumpiest
Default Re: mini me dont understand this
Not enough info.
Old May 5, 2012 | 01:29 PM
EF2SLOW's Avatar
How about this
Its a d15b1 block z6 head pr3 ecu chipped tuned pm6 intake manifold crx si dizzy
I have fuel squirting when I take the fuel rail line off I seem to have no spark but the car turned on earlier
Old May 5, 2012 | 01:40 PM
The Grumpiest
So troubleshoot for no spark.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Old May 5, 2012 | 04:13 PM
m3kid's Avatar
im
having the same problem check the dizzy or your wiring if your wiring is good the its ypur dizzy
Old May 5, 2012 | 07:38 PM
EF2SLOW's Avatar
Originally Posted by m3kid
im
my dizzy was working great on my d15 head I don't understand it has to be timing what I think
Old May 6, 2012 | 08:15 AM
EF2SLOW's Avatar
troubleshot my spark issue pretty dam sure its dizzy I'll find out today after work when I get my new one
Old May 7, 2012 | 09:36 AM
m3kid's Avatar
or it could be your timing you need an adjustable cam gear and advance it 4.5 degrees for the 'half of tooth off' but if you already did then its your dizzy you need a z6 dizzy
Old May 7, 2012 | 09:37 AM
m3kid's Avatar
also it would be better if you did an obd0 to obd1 conversion harness
Old May 7, 2012 | 11:06 AM
EF2SLOW's Avatar
yeah I know I've just been so dam broke lately. I have a vtec converted p06 chipped and tuned and a z6 distributor and z6 injectors and fuel rail
And can't I just cut the injector plugs and distributor plugs and wire the obd1 up directly?
Old May 7, 2012 | 11:14 AM
EF2SLOW's Avatar
instead of buying conversions harnesses
Old May 9, 2012 | 08:09 AM
m3kid's Avatar
nahh i mean you could and there is write ups out the but trust me save your time and buy a conversion harness atleast a cheap one from ebay or if you want a good quality one buy the one off ebay from mono tech everything is easy with his harness
Old May 10, 2012 | 05:52 PM
EF2SLOW's Avatar
I'm just gonna be staying obd0 till I get a swap worth putting cash into thanks for your help guys
xwhitchx
15
Mar 24, 2009 06:14 PM
menappi
19
Jul 27, 2005 09:57 PM
wickedplastikman
Jan 18, 2005 10:15 AM
sodacan33
12
Jun 22, 2004 08:47 PM
USDM 4G VTEC
Jun 25, 2002 01:22 AM
