gearbox mixing
guys i wand to ask you something . i am gona swap to hydro tranny on my crx i have a stock tranny from ek4 sir civic mine is the stock cable of the ef8 . my stock's f.d is 4,2 but gears feel like the stock ek4 sir that has f.d 4.4 are the stock ef8 cable tranny gears shorter that the stock ek4 ? if yes can i mix the gears of the cable with the hydro and create a good short trany ?
Next time ask a real question so it's easier to read/understand.
NO - you can't mix and match hydro and cable gear sets unless you have the YS1 transmission with the external detents like a hydro. The final drives and differentials between B16's can be swapped between the two though. The higher the FD number the shorter the gears.
rice4life
Apr 3, 2002 10:23 PM
