swapping from peak hold to sat... as simple as unplugging resistor box?
Old May 4, 2012 | 07:35 PM
Charlie Moua's Avatar
Default swapping from peak hold to sat... as simple as unplugging resistor box?
i know this sounds dumb....
Im running p/h injectors on my car now.
Q:
if i want to run saturated injectors, is it as simple as unplugging my resistor box and putting on the sat injectors?
it's not like i have to depin anything right?
Old May 4, 2012 | 07:47 PM
Nickeg9Ej1's Avatar
Default Re: swapping from peak hold to sat... as simple as unplugging resistor box?
you have to combine all the wires running to the resistor box together
Old May 4, 2012 | 07:49 PM
what?
like cut and soder them all together?
couldn't there just be a block off plate made for it ?
Old May 4, 2012 | 07:55 PM
Nickeg9Ej1's Avatar
you could make a block off plate been done many times theirs a ton of diys about this, fastest cheapest way is the solder them together
Old May 4, 2012 | 08:50 PM
Spug's Avatar
There is a plug on obd1 harnesses that combines all of those wires while leaving the "pins" on the ends of the wires intact.
two81's
Dec 24, 2013 04:36 AM
crawlin
Aug 17, 2006 06:52 PM
BoostBoi
Nov 13, 2004 11:50 PM
4gZC
Nov 4, 2004 12:27 PM
lilxvtecxpwr
Apr 12, 2004 05:36 AM
