94 b18b sounds like it is missing
Old May 4, 2012 | 01:27 PM
Ls94's Avatar
Default 94 b18b sounds like it is missing
Hello everyone, i just changes my headgj gasket and torqued everything correctly. I timed it and all started it up and it sounds like it is missing. Did a compression check and all cylinders are at 195. I pulled each spark plug wire and they all work. Did the same with the injectors. There is a little smoke coming out of the valvle cover but not bad. Anyone have any idea why it sounds like this. It ran perfect before
Old May 4, 2012 | 01:56 PM
civickiller's Avatar
Default Re: 94 b18b sounds like it is missing
maybe the wire just wasnt on the spark plug good
Old May 4, 2012 | 02:10 PM
Ls94's Avatar
I checked and they all spark
Old May 4, 2012 | 08:08 PM
wires in the right order? all grounds hooked up? take 5 minutes and wire brush each ground
Old May 7, 2012 | 07:59 AM
Ls94's Avatar
Ended up needing a valve adjustment
dabeast111
Jun 5, 2011 08:43 PM
MyHotsh
Jun 5, 2009 04:27 PM
themex77
Feb 17, 2007 02:29 PM
1.8EG-T
Aug 7, 2005 03:46 PM
slowd16z6
Mar 13, 2004 07:12 PM
