Burning oil in 1991 Accord, 240,000 miles
Old May 4, 2012 | 12:16 PM
John Gillham's Avatar
Default Burning oil in 1991 Accord, 240,000 miles
My Accord has 240,000 miles as of today. It has been burning oil ever since I replaced the oil, last November with 5w - 30w. A day later it was smoking like a mosquito fogger in Missisippi on a hot July evening; so, drained the oil again replacing it with 10w-40w. The problem lessened over a course for 4 days, but did not go away entirerly. A year ago and several time since November I check cylendar compression (dry and wet), all 4 read 110 PSI - the low limit.
The car is smoking again, seems to be getting worse. Particularly when starting in cool weather and when the car has been driven for a or so. I suspect values or worn rings may be the problem but do not know how to trouble shoot.
Any suggestions?
Thanks
JW
Old May 4, 2012 | 11:17 PM
Bad_dude's Avatar
Default Re: Burning oil in 1991 Accord, 240,000 miles
Most likely your valve stem seals are all shot. Replace those and you would stop burning oil considerably.
Old May 6, 2012 | 09:32 PM
nus_dogg's Avatar
With worned valve stem seals, the car will puff out alot of grayish smoke as the oil would seep down and sits at the top of the valve neck overnight and/or at idle.
With worned oil control rings, the car will puff out smoke when you're on the acceleration.
Justin Domenic
Honda Accord (2013 - 2015)
Aug 2, 2018 10:07 AM
kirlous k
Jul 4, 2018 11:48 AM
king_pin
Dec 22, 2010 08:27 PM
AccordVT
Jul 12, 2008 10:34 PM
neona
Sep 22, 2004 08:21 PM
