97 accord ex crank sensor
Old May 4, 2012 | 09:36 AM
jlunn717's Avatar
Default 97 accord ex crank sensor
So the car jumps in between shifts, slow pickup, and doesnt go over 75mph (not that i need to). narrowed it down to the crank sensor. how would i go about changing the sensor? whats required to get to it?
Old May 4, 2012 | 09:51 AM
GhostAccord's Avatar
Default Re: 97 accord ex crank sensor
What testing did you do to come to that conclusion?
Is your check engine light on?
If it is indeed the CKP sensor you will have to replace both the TDC and CKP sensor as they come as one. Actually they are combined into one wire harness. They are mounted to the oil pump housing behind the crank pulley.
You need to remove the crank pulley and Lower timing belt cover. I'm pretty sure you'll have to remove the balance belt and drive gear as well. it's been a while since I had to do this and I am no were near my engine to verify.
Old May 4, 2012 | 10:42 AM
jlunn717's Avatar
I used a code reader at advance auto and my neighbors code reader. TDC came up. i assume this is whats causing the misfire aswell. and yes the light is on.
ian1006
Mar 23, 2018 06:08 AM
tougeem2
Nov 15, 2011 05:39 AM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
Brad_and_the_acc
Jun 16, 2009 01:33 PM
lude98SH
Dec 27, 2007 10:32 AM
