Push button start
Old May 4, 2012 | 07:39 AM
morbius18's Avatar
Default Push button start
I made a push button start and drew up the diagram for it. I picked up the stuff at the junk yard and after playing around with the ignition switch, I figured it wouldn't be too hard to simulate with relays.
Items required (almost all sourced from junk yard):
2x 4 pin relays and wiring clips
1x 5 pin relay and plug
Stock 5P ignition connector (brown plug)
Stock 7P ignition connector (brown plug)
2 switches
1 push/momentary switch
The pdf file is a sketched wiring diagram with all the data needed to do this.
In order to have a true push start, you will also have to disable the steering wheel lock as well.
File Type: pdf
Old May 4, 2012 | 07:44 AM
ThePunisherPnc's Avatar
Default Re: Push button start
this is good idea...it would be better if u could do it with some kind of wireless key like the new cars too
07JKX
Aug 26, 2015 04:31 PM
97civicsedan
May 3, 2007 10:55 PM
preludese111
May 9, 2006 07:00 PM
Want2race
Nov 25, 2002 03:53 PM
