Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
Local Oregon place that can repair denso circuit?
Old May 4, 2012 | 06:41 AM
LoveDeezNutz's Avatar
Default Local Oregon place that can repair denso circuit?
I am having an issue with my auto climate control in my EF. the circuit I am referring too is the denso box found under the center console just above the carpet next to the firewall and opens/closes the water valve.
I have tested my broken auto air con and the one I put in to replace it when I broke it and neither temperature adjuster makes the denso unit turn. The unit itself will turn when I manually drop the gear w/ copper on it. It will sometimes turn one direction then back the other.
I doubt its the temperature adjuster because the odds of both units being broken seem low.
The denso unit does get power and does turn.
The temperature adjuster also gets power (at least the light does)
Which leaves me to 2 possibilities.
1. The wiring might be cut (highly unlikely because I would think the wiring wrapped up in would also be having issues.
2. The denso unit itself if messed up.
What type of place would be able to fix/replace this circuit board? Its for a car but I am not sure what kind of auto shop would do this. Maybe some sort of computer place?
I am guessing it receives power since it spins, but no signal since does not move when I turn the ****
Old May 4, 2012 | 07:14 AM
KINGVEM^^ED6's Avatar
Default Re: Local Oregon place that can repair denso circuit?
Call honda?
Old May 4, 2012 | 11:49 AM
Originally Posted by KINGVEM^^ED6
Call honda?
A local honda dealer wouldnt be able to assist me. They wont even replace my seatbelts because its so "modified" its a Japanese/Euro climate control
Old May 4, 2012 | 01:09 PM
racebum's Avatar
if this is different than a usdm setup you're going to have even that much harder of a time. you chat with the guys at forged yet? they are more or less the die hard honda guys in portland
Old May 6, 2012 | 10:15 AM
Thank you, I will call them on Monday hopefully they can help
andrewfreestuff
Aug 24, 2009 09:06 PM
dapek
Sep 28, 2008 09:37 AM
JDubya
Jul 19, 2002 08:34 PM
