1994 Honda Accord
Hi there, I have a 1994 Honda Accord, and recently my D light started to flash from no where. I thought at first it could be my Speed Sensor, that is not the case. This is whats doing, I will start the Engine Specially in the morning and the D light will flush, and when I'm about to take of it will have a rough shift, and travels around 20-30 mph. Sometimes I will pull over and shut off the engine, and turn on back the D light is gone, it drives like a champ. I have just change the Solenoid, and I am thinking now it could be the TCU? please help me with thanks so much.
You can see if you can obtain a TCU you know is in working condition then swap it in.
IIRC, the flashes actually have a pattern and that is your trans fault code. If it is indeed the computer, you can probably buy/install one for much less than $770.
Thanks.
Both of my accords are stick so I don't know much about the TCU codes...
Maybe this can help
TCU Codes:
Long blink = 10
Short blink = 1
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
Maybe this can help
TCU Codes:
Long blink = 10
Short blink = 1
YunkerHonda
Honda Accord 2016- 2017
Jan 22, 2018 03:49 PM
speedracer28
Jul 14, 2010 10:38 PM
