has anybody had trouble with vacuum leaks between the iab plate?
Old May 3, 2012 | 06:26 PM
prelude2.2vtec's Avatar
Default has anybody had trouble with vacuum leaks between the iab plate?
i recently noticed that i have a vacuum leak, whenever i turn off the car i hear a swooshing sound, kind of like a vacuum cleaner being turned off. this sound comes from the drivers side, opposite to the intake. I double checked this by taking a hose and using it as a 'stethoscope' to pin point it. When the engine is running you can hear air moving in the intake manifold right between the iab plate on the drivers side. i have also used carb cleaner to check the leak and i hear the fluid being sucked in but thing thing is i dont know if its being sucked because the gasket is soaked or because of the leak itself . I have already replaced the both gaskets yet i still hear it. has anybody had trouble with this before?
Old May 4, 2012 | 05:48 PM
Default Re: has anybody had trouble with vacuum leaks between the iab plate?
bump
Old May 4, 2012 | 07:52 PM
Hawkze_2.3's Avatar
You only have a vacuum leak if the car idles high or bounces up and down...
76 camaro car
Oct 7, 2014 02:18 AM
TheCrimsonGhost666
Mar 26, 2009 01:40 PM
darkstar1440
Nov 11, 2006 01:57 PM
JICsube
Aug 31, 2002 11:51 PM
