Bad spark wire?
Old May 3, 2012 | 05:58 PM
H22_CB7_JAY's Avatar
Default Bad spark wire?
Can someone tell me the symptoms of a bad or faulty spark plug wire? I've noticed many weird things happening to my car, and I'm wondering what may be the cause.
Old May 3, 2012 | 05:59 PM
Default Re: Bad spark wire?
91 accord jdm h22a
Old May 3, 2012 | 06:09 PM
GhostAccord's Avatar
When was the last time you did a tune up and replaced the cap, rotor, wires and plugs? If you have a multimeter you can test the resistance of your wires. Another way to test them would be to start the car and use a water misting spray bottle and spray the wires. If you see or hear spark leaking from the wires they should be replaced.
Other than that, giving people a bit more detail about your symptoms might help diagnosis of your issue.
Old May 3, 2012 | 07:56 PM
Sorry bro.
I replaced the Intake filter, replaced the IACV, Replaced the PSteering belt, Replaced my EGR Valve + Gasket, and I have a new thermostat ready to go in. The car runs very oddly. When I purchased the car there was a Block off plate on the FITV, I removed that, topped up the fluids. Since then I have this idle issue th at just will not go away. Right now with the car warm, I can rev it (In neutral) to 3gs, and once the RPM's fall (I let it) It drops to 0 and completely dies. My distributor is BRAND new. My plugs are a goldish brown color, and my wires are in decent shape but I have no clue how old they are since I just got the car. I thought replacing them would be a good idea. The only thing I have not tried to fix this issue, is switch out the TB + Mani, and put my H22A4 replacement in..
tocoolforvtec
Feb 15, 2012 10:29 AM
tdubbebawllin
Jul 8, 2008 08:24 PM
black cx
18
Nov 28, 2004 01:05 PM
jagged4698
Feb 11, 2004 04:32 PM
