91 integra rs... driving me nuts.
Old May 3, 2012 | 04:01 PM
Bleezy's Avatar
Default 91 integra rs... driving me nuts.
Alright guys, i could use some advice on this problem. Here is the break down on my situation. I plug the key in i all the lights are good, and i can hear the fuel pump priming. The car will start, but when it gets warm it seems like the gas is getting cut off, and the vehicle turns off. When i try to restart the car, fuel pump does not prime until it cools off.
I have had the following things changed.
Things that have been replaced:
Fuel Pump.
Fuel Filter.
Main Relay
Ignition Control module
I just recently changed the Ignition Control Module, and i thought that fixed it. I drove my care around for about an hour, and the random shutting off stopped. I left my car idling, turned it on and of a few times everything seemed ok. I come back an hour later to start my car... it wont turn on.
I am stumped on what is going on here. Any ideas ?
Old May 3, 2012 | 09:12 PM
Bleezy's Avatar
Default Re: 91 integra rs... driving me nuts.
common guys, i know someone here knows whats up with this.
Old May 3, 2012 | 10:02 PM
newlude8657's Avatar
um is ur car getting overly hot?
Old May 3, 2012 | 10:06 PM
cuz i had the same symptoms in my old car and i did everything u did annnnd turns out i had a small crack in my block that was letting water into one of my cylinders so when it ran it filled with water but after it sat for a while i guess enough drained out to let it start again but i dont know for sure thats just what happened with me..
Bleezy
May 3, 2012 09:59 PM
ef8sleepr
May 4, 2011 01:54 PM
dxhatch93
Nov 17, 2005 01:12 PM
Prentice
Apr 2, 2003 02:04 PM
