!990 Accord Main Relay! Help!
Old May 3, 2012 | 03:29 PM
SeanaK's Avatar
Icon2 !990 Accord Main Relay! Help!
So My car wasn't starting. My mechanic said that it was most likely my main relay, He said those tend to go before the fuel pump. I bought a new relay, installed it, cranked it a few times and she started up. I decided to test it again so i took out the key, cranked it, and she started right up again. I let it idle for a bit and it just stopped. I tried it again and it wouldn't start. it sounded exactly like it did before I changed the relay. I waited a few hours and tried again, but no luck. What could be wrong?
Old May 3, 2012 | 06:37 PM
SeanaK's Avatar
Default Re: !990 Accord Main Relay! Help!
I can hear the relay click but I dont hear the fuel pump.
Old May 3, 2012 | 07:04 PM
Bad_dude's Avatar
How's your plugs and cable? If you suspected fuel, you need to check for fuel pressure at the regulator. Then if the pressure is good then check for sparks. We can't really help you without more details. How's the maintenance? Fuel filter?
Si-Samuri
29
Jun 19, 2008 05:48 PM
Pabs626
Jan 29, 2008 12:42 AM
allmotor2.1
Nov 24, 2007 04:52 AM
uszcrx
24
Sep 9, 2006 01:05 PM
toyorotor
Jun 13, 2005 01:31 PM
