would you go w/itr cams and valve train or skunk2 stage 2 cams and valve train
Old Oct 12, 2002 | 10:44 PM
b16powwer's Avatar
Default would you go w/itr cams and valve train or skunk2 stage 2 cams and valve train
i have a 91 crx si w/b16a1, i wanna go all motor, i would just like to run low 13's w/street tires: heres my ? for you. would you buy a gsr block and but the b16 head on it, or would you build your stock b16 block w/better rods pistons, rings, all the goodies, and upgrade your valve trian to a skunk2 package, cams, valves, ti retainers, srings, and what ever is left out, or would you invest in a gsr block.
thanks for reading, tell me what you think
Old Oct 12, 2002 | 10:49 PM
b16powwer's Avatar
Default Re: would you go w/itr cams and valve train or skunk2 stage 2 cams and valve train (b16powwer)
here are the mods i have to the car, but its not tuned yet.
b16a1, aem short ram intake, thermal catback ss exhaust, power core race cat, jg header, itr trottte body, itr intake manifold, itr cams, skunk 2 cam gears, clutch masters clutch and flywheel, walbro 255lph fuel pump, aem fpr, aem rail, lowered about 2", drilled brakes all around w/axis pads, dc short shifter, vtec controller, chipped pro mugan ecu, gt grant steering wheel and full int, no a/c. 15" rota wheels w/kuhmo tires
Old Oct 13, 2002 | 07:23 AM
STK B16's Avatar
go with GSR BLOCK and build that up and also build the head up with skunk2 . Do the head first then get the block later.
Old Oct 13, 2002 | 08:34 AM
Red_Si's Avatar
Default Re: would you go w/itr cams and valve train or skunk2 stage 2 cams and valve train (Json79)
dude with all that stuff, shouldn't u be in the 13's already??? i think so
Old Oct 13, 2002 | 08:43 AM
b16powwer's Avatar
ttt
thanks all for reading, keep them coming.
JTRO15
May 28, 2012 08:01 AM
Da9teggy92
32
Nov 22, 2008 12:47 PM
flatblack-h22
24
Sep 8, 2007 09:37 PM
flashgsr
Aug 28, 2002 07:40 PM
