hard to start
Old May 2, 2012 | 01:26 PM
projekt90ef's Avatar
Default hard to start
main relay is good and no CEL codes. takes forever to start up (sometimes dies right after start up). If i rev after start up, the car is fine with no issues...exept maybe an idle rpm speed at about 700. starts right up when warm...maybe more turning over then before i had this problem but oh well.
im thinking maybe the ignition switch or sparkplugs but dont want to spend $ on either 1 if one or the other is still good....even if both are still good...
anyone else had this problem before?
Old May 5, 2012 | 12:26 AM
jdmcrx1819's Avatar
Default Re: hard to start
oil on spark plugs maybe. takes a couple of cranks to burn it off to start.
Old May 5, 2012 | 08:10 PM
93delsold16z6's Avatar
Could be oil like he says . Could be engine temp sensor also.
Old May 6, 2012 | 10:37 AM
civicbigpimpin's Avatar
Bad fpr? Can cause fuel to leak back down to tank..extended crank.
Old May 11, 2012 | 10:40 AM
well, the starter cranks kept getting slower and slower so i went to go get the battery tested and it turned out to be a bad battery. got a new battery and it seemed to be problem solved. started great for a few days....now im in the same boat with the hard start...im going to get my starting system tested.
i do have oil on the plugs and wires :/ also going to change the vcg
but will oily plug connections kill a battery? or did i just get a double dose of starting problems?
Old May 16, 2012 | 12:45 PM
having the same problems still...cranking is staying strong with new battery, but still will only start when i RELEASE THE KEY. I dont see why oil on plugs would cause a car to start like that. sometimes have to crank over and over to get to start.
Now, just today, im starting to sputter accelerating from a stop in 1st gear 2-3000 rpm.
please help me, i would rather tackle this problem head on instead of fixing things that are fine already.
Old May 16, 2012 | 07:56 PM
Change the valve cover gasket then report back. If plugs are oily they wont create a good spark to ignite the air fufuel mixturemixture. Do it and rreport back
hhsgraphicarts
Honda CR-V & Element
Nov 23, 2011 11:20 PM
jkalex05
Aug 31, 2009 10:31 PM
mr devious illusions
May 20, 2005 09:56 PM
85civic
Sep 15, 2004 04:55 PM
scrap1ngsr
Dec 10, 2003 06:10 PM
