Type r needs help ASAP! :(
Old May 2, 2012 | 07:35 AM
Yankeeboy504's Avatar
Default Type r needs help ASAP! :(
Ok so first of all, I have a 1998 Integra, jdm front end and everything seems to be wired correctly, well my park light fuse is getting no power, I know I have a short somewhere but can't find it. I started looking around and happens that driver side parking light wires were melte together, ok sounds like I found problem
Right? No... I traced the wire(blk&red wire) back around where brake master cylinder is and cut them out the harness and ran diff wires and grounds, so now there's no short corcuits under hood. Well my park lights still wasn't working, I've done alot of research and yes I'm getting power to that wire with DRLs on. Now when I go back inside car, there's no power to parking light fuse at the fuse box. Fuses are good. So I did more research and read that it might be my switch since the fuse at fuse box receives power from the switchb when DRLs are on, so I went and tapped into wire(red/green) to see if it has power and it does, yet no power at fuse from fuse box. What culd be wrong?
Old May 2, 2012 | 09:34 AM
BlackAckeR's Avatar
Icon3 Re: Type r needs help ASAP! :(
Hmmm, over a 100 views and no replies!?...
Me thinks we need pics to confirm this is caR related!!!
Old May 2, 2012 | 06:41 PM
b16rah's Avatar
Default Re: Type r needs help ASAP! :(
I would recommend checking the wiring again for something you possibly missed. Wiring looks good then move on to your switch. Electrical problems suck, just remember to have patience, you'll find it.
Old May 2, 2012 | 08:46 PM
I'll post pics tomorrow, but some far it's a lost I been working on it all day. RE-did radio wires, nothing. Unplugged radio harness (to test if it's getting a short from radio wires) and it still does it. What I did find interesting was I unplugged the harnesseses from the brain of The alarm, viper 5901. And of course, the relay that was ran wuldnt power up so what I did I ran a fuse to where I originally wasn't gettin power and it powered on! But 2 mins after it blew that aswell, but with the brain connected I get no power to that slot on fuse box. SOOO CONFUSING.
Old May 3, 2012 | 08:52 AM
lzylst's Avatar
Check continuity on the wires in question.
Old May 6, 2012 | 07:26 AM
dc2malta's Avatar
hi guys i need help too if you can. i recently had an accident and the gearbox mounting just sheared off the gearbox housing. gearbox is still oki but i need the housing. its a 99 jdm integra type r. do you know the part number or frome where i can buy one? thx
Old May 7, 2012 | 01:52 PM
Tyrant_007's Avatar
You should create your own thread and you will have better luck getting help. Good luck
traxxasx
10
Aug 10, 2009 01:28 PM
Gvis420
Sep 18, 2008 06:28 AM
Buffalo
Jul 12, 2006 10:27 AM
2LoW4FaThOeS
Audio / Security / Video
Oct 1, 2005 05:13 PM
_Cyclone_
Jul 17, 2005 08:06 AM
