clutch issue
Old May 2, 2012 | 05:08 AM
EurasiaSI's Avatar
10 Year Member
Default clutch issue
b16 tranny in my eg car goes in gear fine with car not running..when car is running will not go in gear..sometimes it will but mostly not..the pressure to the clutch pedal is very slight...alot of play between...bleed slave many times no diff...gets stiff then loses pressure again...is this an issue with my pressure plate or clutch? thanks fellas any info would be appreciative
Old May 2, 2012 | 05:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: clutch issue
Broken clutch spring(s). 94
lopezchris21
25
Nov 19, 2023 08:24 PM
Vinde
Transmission & Drivetrain
Oct 30, 2014 08:14 AM
crazyguy
Jun 21, 2007 08:11 AM
