shaking, popping, clunking, pulling to the left..
i was told it was the ball joints so i replaced the upper and lower. it rides just as bad! nothing has changed.
does anyone know what is causing this? it feels really unsafe to drive.
Sway bar end links can cause the popping/clunking, I'm thinking alignment for pulling to left. Also check radius rod nuts in front cross member, if they have been removed they HAVE to be replaced, one time use only.
GL
Mike
GL
Mike
Its a SH. The ball joint that the radius rod connects to looks a bit worn. Could this be the problem?
It feels so unsafe to drive, you think the problem would be obvious.
