Civic fuel filter issue
Old May 2, 2012 | 04:24 AM
neon2's Avatar
Default Civic fuel filter issue
Hi Everybody!
Can somebody tell me where can I find the fuel filter in my 2005 Civic EP1?
Thanks in advance.
Old May 2, 2012 | 04:28 AM
slyda24's Avatar
Default Re: Civic fuel filter issue
I don't believe they are meant to be serviced, it is located in the gas tank itself on the fuel pump. it's just a screen that keeps sediments from getting into the fuel lines. Why do you suspect that you need to change it?
Old May 2, 2012 | 01:44 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
there is no "filter" only a fuel pump sock.
You can take it off if you'd like and spray it down with brake cleaner to try to clean it out. I was found a part number after hours and hours of searching but never bought it. Just cleaned mine when I swapped pumps
Old May 3, 2012 | 12:38 PM
neon2's Avatar
Thanks for the replies! If it's a part of the fuel pump then fine. I thought it's a separete filter like in other models where it's recommended to change after 50-60 tausend kms. Thanks again!
Mostwantedmecha
Honda CR-V & Element
Jun 10, 2017 04:27 AM
Dohc eg coupe
Feb 15, 2015 05:22 PM
John Haggerty
Honda Civic (2006 - 2015)
Mar 24, 2014 02:56 PM
pjr710
Apr 3, 2010 05:59 PM
