88-91 EF turbo kit and paring out car....check it out lots of parts.
Old May 1, 2012 | 10:41 AM
dukkillertl1000's Avatar
Default 88-91 EF turbo kit and paring out car....check it out lots of parts.
http://s1249.photobucket.com/albums/hh517/ieatv8s2180/
2 88-91 Civic SI trans. LSD $150
good running D16Z6 $400
1991 Civic Base shell with title $750
Front and rear control arms with energy bushing kit installed used 3 races $150
Energy poly motor mount kit all mounts $60
Russell steel brakes lines used 3 races $60
88-91 Civic EX knuckles and prop. valve $120
88-91 rear brake drums, shoes and hubs used 3 races $100
All new Go Autoworks street turbo kit new with tons upgrades, T3 .42 Garrett super
60 turbo, ceramic coated T3 D-series cast manifold, Tial BOV, Precision 39mm wastgate,
RC 550 injectors, custom stainless down pipe, custom breather box with all
AN fittings, all charge piping, 2 core full size radiator and fan kit,
custom valve cover breathers, back door intercooler with heat disbursement
coating, Moroso turbo oil pan, all gaskets. I spent a ton of money on this
turbo kit. Hondata S300 and OBD1 harness. PLX DM5 wideband gauge and O2
sensor. Honda parts all new, t-belt, both crank seals, cam seal and valve
cover gasket set. Over $4000.00 new will part out or sell together for $2800
88-91 Civic Walbro 255 fuel pump brand new $70
949 Racing wheels with Hoosiers but could use tires Bronze 15x9 and 15x7.5 used 3 races $550
new Hondata S300 P28 from HA motorsports $550
90-91 SI gauge cluster $60
2 starters $20 each
1989 Civic SI front and rear seats with 90-91 rails $100
2 88-91 SI intake manofold $40 each
right and left axles $25 each
PLX wideband sensor and gauge $150
Turbo Valve cover $110
Used 3 times D16Z6 Dizzy $120
I am parting out the car so everything is for sale...... 303-720-1393
Old May 1, 2012 | 10:56 AM
93gsrteg's Avatar
Default Re: 88-91 EF turbo kit and paring out car....check it out lots of parts.
Pics of valve cover
Old May 1, 2012 | 11:49 AM
cooperster08's Avatar
Pics of wheels
dukkillertl1000
May 29, 2012 07:09 PM
dukkillertl1000
May 6, 2012 11:17 AM
dukkillertl1000
May 3, 2012 02:48 AM
