Thermostat / Rad Hoses / Cap for JDM Dohc ZC, same as USDM Si?
I just bought a new car (89 crx si rhd dohc zc) and I popped the radiator cap and its very filthy looking in there. Needs a major flush for sure. I figured while I have it apart I should buy new thermostat / rad cap / upper and lower coolant hoses
Can I just walk into the parts store and ask for OEM Crx Si stuff or will it be different??
Might want to go to thezcr.com - there's a sticky there with an entire parts listing.
In short, lower radiator works, thermostat works, upper is an Integra/Accord hose that you have to cut down a little. Cap works, obviously, since you still have the same radiator.
Good luck with everything.
Vagitarian
May 1, 2012 02:58 AM
FourthGenHatch
Apr 27, 2003 03:14 AM
