what is a good 1/4 time for a b18c1 in a 96+ hatch?
Old Oct 12, 2002 | 08:02 PM
-Darren-'s Avatar
Default what is a good 1/4 time for a b18c1 in a 96+ hatch?
thanks?
Old Oct 12, 2002 | 08:03 PM
xxplosif1's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (star&buc)
Low 14's
Old Oct 13, 2002 | 12:17 PM
Turbo C1's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (xxplosif1)
with slicks= 13's
Old Oct 13, 2002 | 01:12 PM
BONER's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (Turbo C1)
I run 15.1 on a 99 hatch w/ a b18c1. (Alot of weight in it. 200lb autopower cage, street tires, etc..)
Old Oct 13, 2002 | 01:38 PM
evil_elmo's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (BONER)
in my sedan i ran a 14.7 with i/h/e
Old Oct 13, 2002 | 05:26 PM
-Darren-'s Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (evil_elmo)
reason i ask is because i'm not sure if i wanna get a b18c1 or b18c5
Old Oct 13, 2002 | 05:30 PM
lazy bum shaughn's Avatar
If funds aren't a problem, get the C5. If you absolutely must get a motor now, save for the C5 haha.
Old Oct 13, 2002 | 05:42 PM
-Darren-'s Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (Breakdancer)
funds won't be a problem. i also plan on waiting a yr. till i go out to buy the motor. to let the money grow some more.
Old Oct 13, 2002 | 09:00 PM
MikeMAN's Avatar
boosted b18
otherwise, the obvious choice is the b18c5
good luck!!!
mike
Old Oct 13, 2002 | 10:00 PM
-Darren-'s Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (MikeMAN)
no i don't wanna run boost, if i wanted to do that i would just put a 1.8t in my A2 golf.
Old Oct 13, 2002 | 10:26 PM
Nameless RB26's Avatar
C5
Old Oct 15, 2002 | 01:05 PM
MikeMAN's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (Nameless)
well, then....u need some c5 lovin' my friend!
Old Oct 15, 2002 | 02:02 PM
giooooo's Avatar
i ran 15.4@89 in my 93 rs integra bonestock street tires weighing at 2650 how the heck you run 15.1 in a gsr swap in a lighter car?
[Modified by Giovannie, 11:03 PM 10/15/2002]
Old Oct 15, 2002 | 02:48 PM
BONER's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (Giovannie)
I award that time to bad driving. And no O2 sensors on an obd2 computer. Too much fuel. I'll get the required sensors installed and a better slip next time. My car is now currently 2705 lbs. (not too light)
15.1@92mph on a 2705lb car isn't too bad. Especially running the check engine codes for no o2 sensors. If I opted to gut the hatch down to feather weight, and fix the check engine problem, I'll burry a low 13 sec time slip close to 100mph guaranteed. But I've already been there and done that. This civic is for show and daily beating.
93 hatch b20vtec turbo
93 t78 supra
99 hatch b18c1 (daily beater)
[Modified by BONER, 11:55 PM 10/15/2002]
Old Oct 15, 2002 | 07:46 PM
giooooo's Avatar
[QUOTE]I award that time to bad driving. And no O2 sensors on an obd2 computer. Too much fuel. I'll get the required sensors installed and a better slip next time. My car is now currently 2705 lbs. (not too light)
QUOTE]
wow that is heavy but that answetrs my questio to your 15.1 1/4 good luck.. id love to have a supra like you lol
Old Oct 16, 2002 | 05:44 PM
BONER's Avatar
My Supra is currently under construction. (HURRY UP HITEC AUTO!)
You don't want a car like this. You guys think a honda is expensive to modify? A supra is a money pit as deep as hell gets...
[Modified by BONER, 2:46 AM 10/17/2002]
Old Oct 17, 2002 | 07:28 AM
SergEK's Avatar
The C5 is a great motor no doubt about it.
But if I could do it all over again I would build a motor from scratch. B18C1 block, JUN 2.0L stroker with 11.5:1 comp , JUN 3 cam package, CTR tranny w/act street disc, Toda ITB's ....this setup is a little spendy but woulc produce some killer midrange and absoloutely pull hard in the top end.
But for a drop in motor that is rock solid daily reliable......a C5 is a decent deal and packs quite a punch for a factory motor...check my sig....its a DX EK.....night and day difference between D16Y motor and C5
Old Oct 17, 2002 | 08:03 AM
-Darren-'s Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (SergEK)
i think i might just go with the jdm itr motor.
Old Oct 19, 2002 | 06:44 PM
F1Spec's Avatar
my friend's car...
98 hatch, b18c1 i/h/e, everything else stock.
15 inch wheels, street tires. 14.7@96mph.
funny thing is tho, my other friend's 98 gsr ran a 14.6@ 97 mph
b18c1, i/h, stock exhaust, skunk2 manifold, p28 ecu chipped with obd2-ob1,
stock wheels, street tires.
both un-tuned.
isn't hatch lighter than a gsr and should hit a faster time? driver?
Old Oct 20, 2002 | 09:57 AM
xxplosif1's Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (fwu)
the gsr is heavier but 96+ hatch aren't 92-95 civic hatch, they're much heavier. My friends 97 hatch is a little bit heavier than my 92 Integra RS.
Old Oct 20, 2002 | 12:37 PM
Wide Open Throttle's Avatar
my 96 hatch b18c with an exhaust runs consistent 14.7's. maybe i can't drag race, or maybe thats what it runs.
HOWEVER if i had to do it over again, i'd get an LS engine, turbocharge it, and forget about it.
Old Oct 20, 2002 | 01:33 PM
-Darren-'s Avatar
last time i check 96+ hatches weighed around 2250-2300lbs.
Old Oct 20, 2002 | 01:34 PM
-Darren-'s Avatar
Default Re: what is a good 1/4 time for a b18c1 in a 96+ hatch? (Wide Open Throttle)
what was your 60ft.?
the only reason i asked was to compare to the itr swap.
Old Oct 20, 2002 | 02:48 PM
xxplosif1's Avatar
maybe with the original D engine but when you get a B swap, disc brake conversion etc...etc...things are getting heavier.
Old Oct 20, 2002 | 03:04 PM
-Darren-'s Avatar
oh, ok that makes sense.
