Need help finding extended lug nuts for XXR 941 wheels?
Old Apr 30, 2012 | 08:55 AM
justBrowsing's Avatar
Default Need help finding extended lug nuts for XXR 941 wheels?
I want the lugs that stick out . I bought a set already but they were "acorn" style and they don't fit so I returned them. Can anyone point me in the right direction? I've heard Muteki Tuner is a good brand
Old May 1, 2012 | 03:42 PM
toyomatt84's Avatar
Sanji
Default Re: Need help finding extended lug nuts for XXR 941 wheels?
Judging by how narrow the lug holes are, you're probably going to need a lug nut that uses a key for installation/removal. They're typically referred to as "tuner lug nuts". I have yet to see an extended lug nut that is tuner style.
Old May 1, 2012 | 06:29 PM
You're right because when I had the rims installed the first time they used nuts with a special key. Ugh I guess I'll just settle for regular ones until I take my saturday class at school where I can work on my own car. Edit: I will actually probably go with some new wheels by that time that the other lugs would work with we'll see.
Someone recommended using extended wheel studs and if you've ever changed the wheel studs on a 7th gen civic you know why i wouldn't do that. have to remove the entire hub :[
triumph_013
Feb 5, 2013 11:25 AM
BLK2DOOR
Apr 13, 2010 09:36 PM
Alpinestar03
Feb 6, 2009 08:55 PM
Confuc1ous
Jan 17, 2004 04:24 AM
greensleeper
Aug 6, 2002 10:22 AM
