92 integra for sale.
I have a 92 integra GS for sale with a 1.7 gsr motor that i swapped in. Car is not running right now. will need a new distributor v tec wires will need to be run too. you will need a new front left caliper too. needs to be bleed. i did the abs delete. you will need to bring your own rims. I will also give fresh rebuild b18a motor with arp rod bolts and b16 pistons. The body is ok not much rust for the year. the inside could us some work mostly drive seat. 1,400 or best offer.
