Torque spec for part# 11107-PK2-003
Old Apr 30, 2012 | 07:05 AM
donut.'s Avatar
Default Torque spec for part# 11107-PK2-003
Hello all,
Would anyone with the helm manual kindly share the torque spec for part# 11107-PK2-003. This is a barb that is plumbed to the oil cooler on h22's. Thanks!
#4 in the below picture
Old Apr 30, 2012 | 04:33 PM
mherkamp's Avatar
Default Re: Torque spec for part# 11107-PK2-003
Just put that German torque on it, you know "Guden-tight"? Lol
*edit I just looked in the service manual and there wasn't a spec in either the cooling or lube section. I'm guessing 28Nm, kinda like the thermo switches, but if you know what size it is, you can approximate the torque based on the size and given its threading into aluminum. If its an M10, it looks like 34Nm into aluminum, if its an M12 its 61Nm. I'd start low, and tighten it if it leaks.
GL
Mike
Old Feb 6, 2020 | 05:24 PM
Immortal_Integ's Avatar
Anyone ever get an actual answer on this?
Old Feb 9, 2020 | 07:51 AM
motoxxxman's Avatar
I can't find a torque spec for this anywhere. Around 30 ft/lbs should be good though. Notice there is thread sealant on the threads too, so if re-using an old fitting you will want to put fresh thread sealant on it. This will not only seal the threads, but also prevent it from coming loose. And there is a difference between thread sealant and thread lock. Make sure to use thread sealant.
Old Feb 9, 2020 | 04:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That spec is probably pretty close... maybe a few ft/lbs more. Looking up that part number from Honda, there seems to be a crush washer that goes with it. Are you still thinking some thread sealant for good measure ? I normally use HondaBond on block and head fittings that do not utilize a crush washer.
Dkahn18
Feb 21, 2009 07:19 PM
Dkahn18
Feb 15, 2009 08:35 PM
ragejed
Apr 8, 2003 02:34 AM
TypeR 508
Mar 18, 2002 09:28 AM
