FL *****00 Civic LX 4dr LS Vtec******
Old Apr 29, 2012 | 07:37 PM
Loumo's Avatar
Default *****00 Civic LX 4dr LS Vtec******
2000 Honda Civic 4dr LX
Clean Title in hand, Located in Sanford area. Just outside of Orlando FL
I have owned this car for a little now and just built this engine that is currently in it. The engine has about 4000 miles on it since it was first started about 3 months ago. I have found another car that I plan on buying so this car has to go. I don't really want to sell this car but I cant have two cars at the same time. I can provide receipts for every part that i have bought for this car including one from the machine shop that shows all the machine work that was done. This car runs great and does not smoke, burn, or leak a drip of anything. I have been driving this car everyday since this engine was built and I have been getting about 30mpg as it sits. I have only run 93 octane, Castrol oil, and OEM honda transmission and power steering fluid. This car was built so it can be driven to Sebring to do a track day on the weekends and then drive to work during the week. The steering wheel and adapter are the only things i want to keep. So either bring your own steering wheel or i can put in another steering wheel.
It has Ice Cold A/c, Power steering. All the power windows work, power locks.
The interior i would rate a 8/10, the two things wrong with it are the head liner is sagging a little in the back and the driver seat has wear in the one bluster.
The exterior i would rate a 7/10, It is original paint so it has scratches, there is a dent in the passenger side rear quarter where the car was backed into at one point in its life. there are also a few door dings.
I am not looking to trade this car for anything, this is for sale only. I have a clean FL title in hand in my name.
It has 178K on the chassis and 4k on the engine
Engine
LS Vtec B18 block and B16 head
Supertech dual springs
Supertech valve guides
Supertech valve seals
OEM valves cleaned up
head and block decked
Supertech 12:1 pistons
Eagle Rods
ACL race bearings
GSR crank
ARP head studs
new OEM oil pump
new water pump
clean oil pan not dented
new OEM head gasket
New OEM oil pan Gasket
New OEM Valve cover Gasket kit
new OEM intake manifold
new OEM throttle cable
DC header
Tanabe exhaust, with test pipe
Blox Gold FPR
Comptech air box with snorkle
every mount has poly inserts
Brand new Accel coil
Brand new NGK spark plugs
every belt was replaced
Mishimoto radiator
Civic Type R intake cam and stock B16 exhaust cam
Removed emissions and IPG block plug installed.
Transmission
B16
no grinds at all
Fidanza 7.5lbs light weight flywheel with brand new friction surface
brand new competition clutch Disc
ACT pressure plate
week old Gator "Road Race" Axles
Suspension
Koni yellow shocks
Ground control extended top hats in the front
Ground control coilover sleeves
Ground control springs
Skunk 2 front camber kit
ST rear sway bar
PIC rear lower control arms
I also have Hard Race rear trailing arm bushings not installed in the car
Brakes and wheels
Hawk HP+ pads with good rotors
rear disc brakes with OEM pads
ARP extended wheels studs
949 lug nuts
Enkei RPF1's
Brand new Falken tires
Interior
Del Sol seats with grey inserts(drivers seat has wear on the bluster from getting in and out of the car
OEM radio block off plate
JVC head unit moved to where the factory CD player was
Vi-RS replica gauge cluster
Steering wheel not included with the car, have steering wheel to go in it
Power mirrors
Power door locks
ECU
Chipped P28
Tuned by Darin at Double D Tuning
Has a jumper Harness
Exterior
OEM Civic Si front lip
OEM Civic si Grill
CTR replica head lights
HID Head light kit
Engine bay bolt kit
Original paint
Ceramic and powder coated parts
DC headers ceramic coated
Custom Splatter coated valve cover
engine brackets, intake manifold, Fuel Rail and radiator stay are all powder coated flat black
I am sure I am forgetting a few things, I also have some random parts that will be included that are not installed on the car yet.
Again I am not looking to trade this car for anything this is for sale only.
Price is $6100 OBO, I can take simple bolt on parts off to make the car cheaper. I am also willing to have the car shipped at the buyers expense.
Feel free to call or text me at 407-879-2395 anytime
Old Apr 30, 2012 | 12:44 PM
Loumo's Avatar
Default Re: *****00 Civic LX 4dr LS Vtec******
TTT
Old Apr 30, 2012 | 01:21 PM
EJ6JON's Avatar
rode in this car...driver gives good road head bump
Old Apr 30, 2012 | 04:34 PM
CRXB5's Avatar
sick 4 door, very clean
Old May 1, 2012 | 04:18 AM
Loumo's Avatar
Thanks, bump
Old May 1, 2012 | 06:00 AM
exratedaccord93's Avatar
So fresh. I'd pick this up if I had the cash right now. GLWS.
Old May 1, 2012 | 10:34 AM
Loumo's Avatar
thanks!!!!!!!!
Old May 2, 2012 | 04:02 AM
Loumo's Avatar
TTT
Old May 2, 2012 | 11:30 AM
Loumo's Avatar
BUMP
Old May 3, 2012 | 04:19 AM
Loumo's Avatar
TTT
Old May 4, 2012 | 05:39 AM
Loumo's Avatar
remember the price is OBO
Old May 4, 2012 | 06:06 AM
markspan6243's Avatar
Flattery Will Get You Everywhere
looks nice. glws
Old May 4, 2012 | 10:24 AM
Loumo's Avatar
TTT
Old May 5, 2012 | 04:27 PM
Loumo's Avatar
Bump
Old May 8, 2012 | 09:26 AM
Loumo's Avatar
TTT
Old May 8, 2012 | 09:43 AM
valiente540's Avatar
If you weren't in Florida!! GLWS
Old May 8, 2012 | 11:49 AM
Loumo's Avatar
I am willing to ship this car
Old May 8, 2012 | 06:26 PM
Loumo's Avatar
BUMP, i made some changes in the price check it out
Old May 9, 2012 | 11:02 AM
Loumo's Avatar
TTT
Old May 10, 2012 | 05:29 AM
Loumo's Avatar
I would love to see this car sold!!!!!!
Old May 10, 2012 | 06:34 PM
Loumo's Avatar
TTT
Old May 12, 2012 | 02:19 PM
Loumo's Avatar
BUMP
Old May 12, 2012 | 06:02 PM
yeah but im not trying to pay 500 or more to have it shipped up here. If i get really desperate i just might. i need a car by end of june
Old May 12, 2012 | 09:37 PM
Loumo's Avatar
If you where serious i could arrange something, also you could fly down to get the car and drive it back. Air fair is cheap... wink wink
Old May 13, 2012 | 03:14 PM
Loumo's Avatar
Ttt
