Go-Autoworks D-series Turbo kit and lots of other parts....
http://s1249.photobucket.com/albums/hh517/ieatv8s2180/
Koni race valved and shortened with Ground Control coilovers 600lb and 500lb springs. energy top bushings used 3 races $1300.00 obo
Ingalls front and rear poly. alignment kit. used 3 races $140
ASR bar with 1 call level higher used 3 races $350
3 88-91 SI transmissions one with Quaife LSD $350 without LSD $150
good running D16Z6 $400
1991 Civic Base shell with title $750
Front and rear control arms with energy bushing kit installed used 3 races $150
Energy poly motor mount kit all mounts $60
Russell steel brakes lines used 3 races $60
88-91 Civic EX knuckles and prop. valve $120
88-91 rear brake drums, shoes and hubs used 3 races $100
All new Go Autoworks street turbo kit new with tons upgrades, T3 .42 Garrett super
60 turbo, ceramic coated T3 D-series cast manifold, Tial BOV, Precision 39mm wastgate,
RC 550 injectors, custom stainless down pipe, custom breather box with all
AN fittings, all charge piping, 2 core full size radiator and fan kit,
custom valve cover breathers, back door intercooler with heat disbursement
coating, Moroso turbo oil pan, all gaskets. I spent a ton of money on this
turbo kit. Hondata S300 and OBD1 harness. PLX DM5 wideband gauge and O2
sensor. Honda parts all new, t-belt, both crank seals, cam seal and valve
cover gasket set. Over $4000.00 new will part out or sell together for $2800
88-91 Civic Walbro 255 fuel pump brand new $70
949 Racing wheels with Hoosiers but could use tires Bronze 15x9 and 15x7.5 used 3 races $550
new Hondata S300 P28 from HA motorsports $550
90-91 SI gauge cluster $60
2 starters $20 each
1989 Civic SI front and rear seats with 90-91 rails $100
2 88-91 SI intake manofold $40 each
right and left axles $25 each
PLX wideband sensor and gauge $150
Turbo Valve cover $110
Used 3 times D16Z6 Dizzy $120
I am parting out the car so everything is for sale...... 303-720-1393
2 starters $20 each
SI tranny with quaife LSD for $350? hondata? is it boosted by gears? I also want to know how much for the intercooler set up! and prices individually for the tial and precision blowoff valve and wastegate. Separated prices and price for all together. Im interested!
dukkillertl1000
May 6, 2012 11:17 AM
dukkillertl1000
May 3, 2012 02:48 AM
dukkillertl1000
May 2, 2012 07:32 AM
dukkillertl1000
May 1, 2012 11:49 AM
