ABS Removal Harness?
Old Apr 28, 2012 | 11:47 PM
Steeve_Civic's Avatar
Default ABS Removal Harness?
Hello,
I need to remove the ABS harness.
Is there some picts on diagram to help me?
I removed all Orange Plugs but the harness seems to go behind the dashboard?
Can I cut it witout any problems?
Thks
Old May 1, 2012 | 01:41 PM
Default Re: ABS Removal Harness?
Can I cut all Orange connexions without problem with the ECU?
Old May 5, 2012 | 01:26 AM
Jdm Accords's Avatar
it's seem no one unable to answer you Question... me neither can't help you... i just suggest you try to surf at google.
Old May 7, 2012 | 08:09 AM
sniff, no one has ever removed his OEM ABS harness?
Thks
Old May 7, 2012 | 12:30 PM
lsturbo33's Avatar
I did in my 97 Integra. I removed all the wires connected to the orange plugs and unpinned them at the ecu or wherever the went. It's been like 3 years since I did it but I didn't have any trouble after wards.
Old May 7, 2012 | 12:31 PM
lsturbo33's Avatar
The abs has it's own ecu if I remember right. I think it's in the passenger side quarter panel area.
Old May 7, 2012 | 12:42 PM
kyden's Avatar
i suggest you grab a helms manual and trace the wiring. then you'll know what wires you can or can't remove.
vtecjunkiie631
Sep 15, 2018 07:19 AM
jarel
May 14, 2015 06:34 AM
D3U1LT
May 14, 2015 06:31 AM
adictionbass
Jan 12, 2005 04:14 PM
