91 civic clutch saftey switch
Old Apr 28, 2012 | 04:19 PM
osbunjosh's Avatar
Default 91 civic clutch saftey switch
My 91 civic STD 5 speed doesn't seem to have a clutch safety switch. Is it suppose to? and would that cause my fuel pump not to prime?
Old Apr 28, 2012 | 10:45 PM
Stunna MIKE's Avatar
Default Re: 91 civic clutch saftey switch
it might just be jumped.. almost all hondas ive owned the switch was jumped..
check the main relay
Old Apr 29, 2012 | 05:02 AM
shiroun's Avatar
Check grounds and main relay.
Mike is right. One of the first "mods" most older honda owners do is jump the clutch safety switch.
Why, you might ask?
If you look behind the clutch safety switch, you'll see a little rubber piece. This is called a "break stopper switch/clutch stopper switch" and it breaks quite often in 90's hondas. When it breaks on the clutch safety switch, you WILL NOT be able to start the car since the circut isn't completed.
Old Apr 29, 2012 | 08:27 AM
M-benz's Avatar
It's happened to me like two weeks ago ... That little breakstopper is in blue color . It took me a while to figure that out after replacing a lot of parts .
riverman223
Jun 7, 2014 03:42 PM
josh352727
Aug 19, 2011 08:54 AM
John 07
Nov 10, 2008 05:30 AM
