Intake and exhaust cam adjustments.
I have a dohc ZC and just recently installed some AEM adjustable cam gears.Does anybody have any suggestions on where I should set them at.I don't have access to a dyno so I'm kind of clueless.
unfortunately a dyno is the only "real" way to find lost power. Most of the time advancing the in cam and retarding the ex cam make a small increase in power. Like I said though a dyno is the only way to really make power.
Well If your good at feeling slight increases in power than you might want to do as descibed above by 5 degrees each way, and than go from there
[Modified by azroth, 4:48 PM 10/15/2002]
