Question about the integra brake swap
Old Oct 12, 2002 | 05:14 PM
civichopeful's Avatar
Default Question about the integra brake swap
Does anyone have this done? I have a 91 civic hatch with a 1991 integra doner car. How difficult is it and what parts do I need? Will I be able to use my stock axels with the integra hubs? Thanks ahead of time
Old Oct 12, 2002 | 07:34 PM
crxcess's Avatar
Default Re: Question about the integra brake swap (civichopeful)
you are probably going to have to hybrid the axles. My 91 crx si was done the other way around for a while. it had the b16a. the axles were also from an integra, the outer cv joints were swapped from the old crx axles. I went ahead and swapped in the front brake setup from a 92 integra. Changed the axles to fit the integra hubs. other than the hub, rotor, caliper, and upper control arm, that was it.
Make sure you get the spacers from where the axle fits into the hub. If you forget, there will be some play in there.
Old Oct 13, 2002 | 03:42 AM
Default Re: Question about the integra brake swap (crxcess)
Cool. Thanks.
OOOtony
Feb 28, 2009 04:44 PM
Ahh Vtec
Jan 4, 2008 08:23 AM
trevdawg
Feb 17, 2007 04:02 PM
anotheredhatch
Aug 19, 2004 06:11 AM
joey1320
Dec 17, 2002 04:20 PM
