FS: 98 ITR Motor/Trans
Old Apr 27, 2012 | 09:51 PM
Boosted T-4's Avatar
Default FS: 98 ITR Motor/Trans
Complete ITR longblock and Trans.
This will include stock b series mounts.
I will also include the Tri Y header.
$3,600
Old Apr 28, 2012 | 06:21 PM
Default Re: FS: 98 ITR Motor/Trans
The motor has 50k on it.
I will also deliever to anywhere as long as the buyer throws a little gas money in.
Old Apr 29, 2012 | 03:17 PM
Top.
Old Apr 29, 2012 | 08:31 PM
mRek9R's Avatar
I've got a few questions for you!
Compression test?
Leaks/Noises?
Overall engine health?
Transmission health?
- Smooth shifting? (when I mean smooth shift I mean that...almost no force needed to shift)
- Any gear grinds?
Is this engine a '98 USDM or JDM ITR engine?
Is trans JDM or ITR?
Old Apr 29, 2012 | 09:33 PM
A guy that looked at the car a few years back wanted to do a compression test on the car. The numbers are as follows: 245, 250, 251, 250
The motor doesn't leak or have any weird noises. The motor is very healthy.
The trans has the 3 gear grind, so it will probably end up needed new syncros. It only grinds at high rpm's. It shifts smooth other than that.
This is the B18C, the JDM Integra motor and LSD trans. This motor is from hmotors. So it is not a junk swap.
Let me know if you have any other questions.
Old May 1, 2012 | 10:34 PM
Top.
Old May 6, 2012 | 03:52 PM
Bump.
RacerZook
Northern California (Sales)
37
Dec 10, 2009 06:37 AM
TEAM562racing
Oct 15, 2003 01:55 PM
