1990 Civic STD Rad Fan
Old Apr 27, 2012 | 07:42 PM
uncleauzzie's Avatar
Default 1990 Civic STD Rad Fan
Hi there,
n00b question......
When should my rad fan be engaging? Should it fire up when they key is turned to ACC?
Noticed engine is getting hot, can't confirm if the rad fan is firing up or not.
Anyway to troubleshoot?
Any help is appreciated!
Cheers!
Old Apr 27, 2012 | 10:31 PM
KINGVEM^^ED6's Avatar
Default Re: 1990 Civic STD Rad Fan
First run power drirectly too fan too see if its the fan
Second check fan.switch on the back of the block
Also check wiring for ignition switch
Old Apr 29, 2012 | 06:19 AM
jlicrx's Avatar
cooling fan comes on when coolant temperature reaches about 195*F and goes off when coolant tempearture drops to about 185*F
fatl13ert
Oct 22, 2012 12:41 AM
Flatlandz
Honda Civic (2001 - 2005)
May 2, 2010 12:32 PM
quick_ls
Mar 9, 2006 05:56 PM
SpoonREVS
Jan 24, 2006 05:42 PM
mycivicisslowasfuck
Oct 25, 2004 08:51 AM
