EGR .. True meaning?
Exhaust Gas Recirculation. It recirculates exhaust gases into the combustion chamber to lower combustion temps at cruise speeds to lower NOx emissions. If there is nothing wrong with the EGR valve itself, then nothing. The common issue is the ports in the intake manifold become clogged with carbon and soot. This impedes or stops flow of recirculated exhaust gases. If your current valve operates normally but you still have slight bucking at part throttle cruise, or high NOx emissions then most likely there is blockage in the EGR ports.
Now, I did notice that the port holes have been tampered with, and.. The EGR valve I took off REALLY was not that bad.. I do have the bucking at slight throttle. It looks to me like the port holes have been tapped out and jb welded back in. Should I consider getting in there? Or should I assume the EGR valve (old one) would be as clean (Some carbon, I expected more) as the ports?
I hope they were not JB welded back into place, that would suck.
I would recommend removing the plugs, making sure that the ports are clean not just underneath the plugs, but that the passage from the EGR valve down through the intake manifold is also free and clear of debris. Same with the feed passage from the exhaust side. Engine cleaning brushes can be purchased for rebuilds. http://www.summitracing.com/search/?...ng%20kit&dds=1
I have MGR-5189. I have used this kit so many times on cleaning EGR passages it's not even funny.
In the FAQ look up this http://home.comcast.net/~em-engineering/T2T013.pdf The F series used in CBs you can purchase a new plug kit for the removable plugs on 90-93 cars is Honda P/N 17199-PT3-AHM.
If you have a H22 I am not sure how the EGR system is serviced.
I have an H22A Full motor and tranny swap.. I have some f series parts still on the car like power steering, n others. What other way could they have closed the port holes? It looks like some kinda putty that hardened inside after they let it sit?
Look around for pictures, or ask fellow members, of umolested H22 intakes. See if the EGR plugs are like the 90-93 F22s.
The egr plugs are still the F series connectors, aswell as the EGR valve. Should I try to tap it out gently? Or should I consider replacing it, Honestly I think this is the culprit for my insanely odd idle.
The only way that the EGR system would mess with idle is if the EGR valve does not properly seal when in the closed position, allowing exhaust gasses to enter the manifold unmetered. Or the crap goo job that was done may be leaking allowing a vacuum/false air leak. Or a combination of both.
That makes sense. I always found it odd since almost any other engine from that era had an EGR valve.
unless you guys have to pass emissions (DEQ), i would just blockoff the egr. on my h22 its blocked off. you can find the blockoff plates on ebay or my favorite Rosko Racing. dont worry it dosent throw a code
OOMPF!
If the intake manifold egr ports were not properly cleaned then they could still be hampered by carbon and soot.
Which size brush from that kit do you use for the EGR runners? I have this kit from Harbor Freight and wonder which one might work the same. http://www.harborfreight.com/9-piece...set-90631.html
I also wonder if this kit would work also. http://www.harborfreight.com/10-piec...kit-95947.html
Thanks.
Hey Mike,
Thanks.
Thanks.
On my daughter's car the passage under the EGR valve is blocked. Does this crud stand the chance to block the oil pick up screen.
How long do the brushes need to be?
I am guessing that removing the oil pan would be the thing to do?
Thanks,
Tortis
This is on a 99 Accord 4 cyl.
Thanks,
Tortis
No. Unless you remove it from the EGR passages and add it to the oil.
Long enough to comfortably use.
Huh? The EGR passages are from the exhaust to the egr valve to the intake. No oil pan or passages are ever accessed. The VTEC solenoid may be next to the EGR valve but they do not share any passages or ports.
Long enough to comfortably use and a diameter slightly larger than the EGR passages.
No, I do not know what size the passages are off the top of my head, measure the size of the plugs on the intake and that will be what you are aiming for.
Sorry, lol, not real familiar with the EGR system.
I had the EGR valve off and didn't want to clean it for fear all the crud would end up in the oil pan.
I feel like a dumb ***. HAHA
Thanks. I will clean the system well.
Can anything be done to keep the build up from coming back?
Tortis
Tortis
A WOT blast on the freeway onramp every now and again will help a bit.
The most commonly carbon fouled cars are the ones that live a very docile lifestyle put-putting around the neighborhood.
It won't end up in the oil pan, but if you do not clean it out of the egr ports after breaking it loose it can get stuck in the intake or keep a valve from seating. Use a vacuum while scrubbing to evacuate the crud.
i really appreciate the help
T
Just to throw another suggestion out there for the port cleaning Ill relay what I did the last time I did the job.
In trying to prevent any carbon from falling into the runners and therefore into the combustion chambers I duct taped a hollowed out mechanical pencil to the end of my shop vac hose.
This focused the vacuum in a narrow area and cleaned the majority of it right out.
Applying some berrymans or other cleaner would also help loosen any stubborn deposits.
Just food for thought...
