EX w/ ABS vs DS front hubs
I am trying to confirm a few dimensions between these two hubs. Does anyone have info that would help? Or a pic of the DX hub that I can compare to my EX?
questions:
1. Is the outer diameter (that fits in the bearing) different between these two hubs?
2. Is the bore protrusion (the center that your disc and wheel slip over) a different length on both? I am using the Summit 11" wilwood kit and the center does not protrude enough to allow the wheel to slip over it, making the wheels not hub centric.
questions:
