Headlight question
I am trying to replace a screw that holds the top of the headlight but I am not sure which one it is. Can anyone identify which item it is in the diagram?
I was actually referring to the philips head screw that's going through the top of the headlight just under the radiator support. It's longer than the one you are suggesting.
I believe the one you're referring to is the tilt adjusting screw. I believe it's the rod that goes with 15 which goes with the spring. There is no long screw on the itemized list.
577HondaPrelude
11
Jan 20, 2005 07:20 AM
