Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Password:JDM Ultimate Rear Toe Links 88-00 Civic / 90-01 Integra
Old Apr 26, 2012 | 10:11 AM
passwordjdm's Avatar
Default Password:JDM Ultimate Rear Toe Links 88-00 Civic / 90-01 Integra
Modifying suspension for most people usually starts and stops with lowering a car using springs or coilovers… And that's where the problems begin. Changing the ride height on a car changes everything else. Toe settings and camber angles goes to sh*t and always resulting in a poor drivability. Having the correct suspension setup involves more than just ride height, it always requires having the corrected camber angles, and proper toe settings as well. This is always overlooked all because the way people seem to test the drivability of a car is to drive it straight. By lowering a car equally on both sides, you will always create an even toe-in or toe-out condition. Your car will drive straight since the toe is either pulling or pushing evenly, and unless you know what to feel for, it will also drive like ****. Having the toe settings off will create a unwanted over/under steer condition. The Password:JDM Ultimate Rear Toe Links will help you fix this problem and also eliminate the sloppy rubber bushings in the process.
The new patent pending Password:JDM Ultimate Rear Toe Links allows for quick and easy adjustment of any rear toe problems your car might have. Just like the Ultimate Rear Camber Links, the Password:JDM Ultimate Rear Toe Links uses a track-grade, self-lubricating Teflon lined spherical rod ends with zero maintenance that provides superior performance over polyurethane and rubber bushings. Coupled with these rodents are CNC machined stainless steel misalignment spacers that makes it all come together. There's nothing to bind, deflect or blow out at either end so you can be sure that "the position for the win" stays that way... Well, at least until you monkey with the set-up again. Being able to fine tune your suspension needs makes this a required part of your arsenal and will save you money from replacing prematurely worn out tires, make you safer and make you faster. You won't find a Rear Toe Link with a better design and more adjustability than these. Like all of our other suspension products, we designed these to be better than anything else on the market… that’s why they are called the Password:JDM Ultimate Rear Toe Links!
- Track Grade, self-lubricating Teflon lined Spherical Rod End Bearings
- Maximum amounts of adjustability in fractional degree resolution
- CNC machined Stainless steel misalignment spacers
- Anodized aluminum CNC machined Adjustment Turnbuckle
- Grade 8 locking hardware
- Eliminates rubber bushings
- Available in many colors
- 100% rebuildable
- Made in house in the USA.
This item qualifies for FREE SHIPPING to the 48 contiguous states.
Old Apr 26, 2012 | 03:52 PM
Default Re: Password:JDM Ultimate Rear Toe Links 88-00 Civic / 90-01 Integra
up
Old Apr 27, 2012 | 07:52 AM
up
Old Apr 27, 2012 | 10:14 PM
FlewByU352's Avatar
How much? Couldn't find them on your site.
Old May 1, 2012 | 09:02 AM
PM's Replied!
Old May 9, 2012 | 01:30 PM
up
Old May 10, 2012 | 04:58 AM
EJ8freek's Avatar
Bump.
Old May 17, 2012 | 10:49 AM
Originally Posted by EJ8freek
Bump.
thanks!!
BoostThisMS
May 3, 2013 10:33 AM
passwordjdm
May 17, 2012 10:49 AM
preludeNApower
Suspension & Brakes
Aug 8, 2011 06:23 PM
killer_Bseries
Suspension & Brakes
Jul 26, 2011 03:08 PM
Todd00
11
Aug 10, 2001 05:36 PM
